3RIC: A Homebrew 6502 Computer, Built to Learn
A homebrew 65C02 with logic-built VGA, stereo sound and SD storage. From breadboards to PCB, with a browser emulator to explore.
0 followers
My homebrew 6502 computer. Designed and built from the ground up to run LodeRunner, evolved and adapted to run Ultima IV and now a bunch of Apple II software. Implemented with 74 series logic . Produces a native VGA display capable of rendering all of the basic Apple II+ graphics modes. Includes integrated audio compatible with the Mockingboard as well as native support for PS/2 keyboard, SNES gamepads (adapted in software to Apple II joystick - oh boy was that interesting!). Has an original DOS for loading from a Micro SD card via bitbang'd SPI over a 6522. Native FAT32 implementation in 6502 assembly (Thank you George Foot for all of your help here). Also includes a Pi Pico that implements an original Disk II emulation that shows up on the PCB as a device. I still can't believe it works, and it sits on my desk now. I turn it on every day to remind me that I can accomplish way more than I think I can if I just start moving.
https://youtu.be/2o7yUwbXKFI?si=aSkp7rHIYvhriOoG
I wanted to understand how a computer really works. So I built one.
3RIC is my homebrew, Apple-II-class 65C02 computer: a real processor, RAM and ROM, custom VGA circuitry, a great many logic chips, and a long trail of breadboards.
It started as a learning project. Then I gave myself a target: get Lode Runner running on a computer I designed. That goal pushed me into video timing, memory maps, assembly language, storage, sound, and eventually a custom PCB. After Lode Runner, I aimed higher: Ultima IV. I finished the game on 3RIC.
Watch the 2:45 build overview:
Try the machine yourself: 3RIC Studio runs my emulator in a browser, with no installation or account. The Built from Bits showcase is a quick way into its graphics, sound and editable 65C02 source.
Why build an 8-bit computer now?
I grew up with an Atari 1200XL and a fascination with computers. As a software engineer, I could use a computer, but I wanted a less abstract understanding of how one works.
Ben Eater's 6502 kit gave me a starting point in 2020. Before this project, I had never touched a breadboard or done hardware engineering. I did not begin with the finished machine's design or a clear route to it. I learned enough to solve the next problem, then discovered the next one.
An 8-bit machine is a wonderful scale for that kind of learning. You can follow a keypress through an interface, into a ROM routine, out into memory, and finally onto a display. The wires and timing are visible rather than hidden behind layers of software.
The point was not to outperform a modern computer. It was to build something I could understand, explain, and enjoy using.
A real computer, not just a display demo
The finished machine combines:
  • A WDC 65C02, running at approximately 1.573 MHz in the final VGA design.
  • Custom hardware-generated VGA, with text, low-resolution color and Apple-II-style high-resolution graphics.
  • Shared CPU/video RAM, with timed access so the processor and video circuitry can use the same memory.
  • 74-series address-decode and control logic. The earlier 22V10 experiments are part of the history, not the final implementation.
  • A 512 KB system flash/ROM device, with banked firmware, monitor and DOS routines. Device capacity is not the amount visible in the CPU's address space at once.
  • PS/2 keyboard and mouse, two SNES controller interfaces, and ACIA serial I/O.
  • MicroSD/FAT32 storage and a custom DOS, plus a Pico-based Disk II emulation interface for the physical machine.
  • Two AY-3-8910 sound chips, driven through two 65C22 VIAs in a Mockingboard-style stereo arrangement: six tone channels, plus the separate system speaker.
The Raspberry Pi Pico in the disk subsystem is a peripheral, not the main CPU and not the source of the machine's VGA graphics. The separate Badger6502 Pico emulator experiments in my channel are related projects, not a substitute for this physical 65C02 build.
The part I am proudest of: video and timing
The Apple II was an attractive target because of its relatively simple graphics hardware and its software library. But recreating its behavior on a VGA display was not simply a matter of copying a memory layout.
The Apple II's famous high-resolution colors arise from the behavior of an NTSC composite signal. I wanted those software-visible color effects on VGA, so I reproduced the artifact-color behavior using logic circuits.
The CPU and video circuitry also share RAM. They must take turns: the CPU uses one part of the clock cycle, and the video hardware uses the other. The video path reads bytes, loads shift registers, and turns their bits into the signal on the monitor.
High-resolution Apple II graphics add another wrinkle: seven displayed pixels per byte, with the remaining bit affecting color timing. I explored a 4046 phase-locked loop to obtain the related pixel clock. The breadboard experiments, oscilloscope traces and color tests were how I learned what the design actually needed.
It is easy to look at...
3ric-breadboard-model-and-logic.zip
The .diy breadboard model and Logisim address-decode/color models, with licensing notices and revision guidance. These are historical design models rather than a verified final-board netlist or manufacturing package.
x-zip-compressed - 55.96 kB - 09/14/2026 at 17:44
Download
3ric-breadboard-layout-snapshot-2024-09.pdf
Original full-size, single-page PDF of the DIY Layout Creator breadboard model used to document connections and reconcile the schematic. Useful for studying the development machine, not a final PCB assembly drawing.
Adobe Portable Document Format - 3.97 MB - 09/14/2026 at 17:44
Preview
3ric-schematics-snapshot-2024-09.pdf
Original 19-page schematic PDF from the repository, last updated there on 27 September 2024. Includes clock/video, RAM, CPU/ROM, I/O, decode/banking, PLL and sound. Retains development annotations; do not assume exact correspondence with the later Gerbers.
Adobe Portable Document Format - 2.19 MB - 09/14/2026 at 17:43
Preview
3RIC_GERBER_11_16_2024.zip
The Gerber archive Eric Badger confirmed he submitted to JLCPCB. KiCad 8.0.5 export with four copper layers, front/back masks, paste and silkscreen, outline, plated/non-plated drills and job metadata. Preserved unchanged. See 3ric-gerber-file-notes.txt for provenance and repeat-order context.
x-zip-compressed - 1.84 MB - 09/14/2026 at 17:41
Download
  • Now anyone can explore the machine
    ebadger5 hours ago 0 comments
    2026 update: the browser tools, showcase and challenge overview.
    The physical computer is built, but sharing an 8-bit machine is easier if people do not need my workbench to try it.
    My C++ emulator runs the 3RIC ROM and models the machine's memory and peripherals. The same core now runs in a browser through WebAssembly. 3RIC Studio adds an assembler, debugger, tutorials and a program gallery so someone can go from watching the machine to changing a program.
    For the showcase, Built from Bits provides a short tour: a hi-res starfield, 16-color plasma, a rotating wireframe and an original six-channel musical sequence. The 65C02 executes the display and music code; the browser is the host, not an animation shortcut.
    The distinction from the hardware footage is important. These recent programs are demonstrated on the emulator. Built from Bits targets 3RIC's VIA and sound hardware, but this is not a claim that I have run that new program on the physical board.
    Start at 1x, click inside the emulator for sound, and try 1-4 to change scenes. Space pauses, M mutes, and Q/Esc returns to the monitor. Open the source, change something and run it again. A WOZ export packages the program; it does not change which machine the program needs.
    The new 2:45 film collects the physical build journey for the Retrocomputing Challenge. It complements the design files and logs rather than replacing them.
    Build highlight reel:
    Interactive showcase: https://ebadger.github.io/3ric/hackaday.html
    Open the source: https://ebadger.github.io/3ric/index.html?src=programs/hackaday.s#ide
    Tutorials: https://ebadger.github.io/3ric/tutorials.html
    Built to learn. Shared to explore.
  • Ultima IV, completed on a computer I built
    Retrospective build log: December 2024 and the March 2025 wrap-up.
    Getting Lode Runner running was the first big target. Ultima IV became the next one: not just a title screen or a brief demo, but a game I could play through on my own computer.
    In December 2024, I finished it on 3RIC. That was a different kind of satisfaction from making one circuit work. It meant enough of the complete machine was cooperating, consistently, for me to use it for its intended purpose.
    The March 2025 wrap-up shows the populated board in its case and talks about further experiments with serial terminals and an ImageWriter II banner program. It also covers the things I would do differently.
    The final VGA design ties the processor to approximately 1.57 MHz. That affects compatibility with software that counts cycles or expects Apple II timing. My ROM and I/O are different too. The PS/2 software taught me about interrupt and timing costs, and the PCB taught me to think harder about passive part sizes and even which way the silkscreen will face in the case.
    I do not regard those differences as something to hide. They are part of what makes this a learning project rather than a claim of a perfect Apple II clone.
    The completion video:
    The wrap-up, including lessons and limitations:
    Original completion post:
    https://www.reddit.com/r/Ultima/comments/1hhkeuv/finished_ultima_iv_on_my_homebrew_computer/
    Banner-program source: https://github.com/ebadger/banr4000
  • Trace every wire before committing it to copper
    Retrospective build log: the 2024 transition from breadboards to PCB.
    By this stage the breadboards worked, but the schematics had not kept up with every experiment. Turning that into a PCB was not just a layout exercise: first I had to recover an accurate picture of what I had actually built.
    I considered taking everything apart wire by wire. Feedback from other builders convinced me to preserve the working machine instead. I used DIY Layout Creator to make a digital breadboard model, checked connections with a multimeter, and gave each board and chip a coordinate.
    That made it possible to work systematically between the physical build, the wiring model and the schematics. It also exposed duplicated logic and opportunities to simplify. Documentation was not something I did after the engineering; it helped me finish the engineering.
    The next stages were placement, routing, assembly and bring-up. I used surface-mount passive components alongside the larger logic devices and gained plenty of soldering practice. Eventually the sprawling breadboard build became a working board in a case.
    The project files preserve different points in that journey. The schematic and DIYLC PDFs are September 2024 snapshots. I have also included the Gerber ZIP I submitted to JLCPCB, generated on 16 November 2024 with KiCad 8.0.5. It contains the four copper layers, masks, paste, silkscreens, outline and plated/non-plated drill files.
    The older KiCad PCB in the repository is historical and is not that later fabrication export. Read the file notes before using either set. For a repeat order, use the original JLCPCB order options rather than assuming the archived CAD job fields contain those choices.
    The story of the transition:
    An early populated-PCB demonstration:
  • Make it useful: storage, controllers and stereo sound
    Retrospective build log: 2023-2024 peripheral and software work.
    Being able to load and save files makes a homebrew computer much more pleasant to use. I integrated SD/FAT32 work into my firmware and built up a DOS, drawing on George Foot's 6502 SD routines and contributions that added writing support.
    Open-source programs were excellent integration tests and good examples to learn from. I added an EB6502 target in my cc65 fork and ported programs including Chess, Gomoku and Breakout. The point was not to claim authorship of those games; it was to understand the runtime and machine-specific work needed to bring them across.
    SNES controllers were another satisfying bridge between generations. The pads return digital button states serially, while Apple II software often expects an analog-style joystick interface. The VIA, firmware and soft-switch behavior had to cooperate.
    The sound subsystem uses two AY-3-8910s and two 65C22 VIAs in a Mockingboard-style arrangement, giving three tone channels on each side. The AY clocks come from 3RIC's clock, which is not the Apple II's clock; that difference matters to pitch and timing.
    The physical disk-emulation subsystem uses a Raspberry Pi Pico. It is a peripheral alongside the real 65C02 and hardware VGA, not a Pico emulating the whole computer.
    One video also records an important design change: the 22V10 was replaced with discrete logic. The finished machine is not the earlier GAL prototype.
    Storage and software ports:
    Controllers and the discrete-logic change:
    Disk-emulation demonstrations:
    Firmware development: https://github.com/ebadger/msbasic/tree/newboard
  • VGA, shared RAM, and the seven-pixel problem
    Retrospective build log: video experiments and the 2023 breadboard redesign.
    The first video experiments were simple: wire up enough logic to generate a signal, display color bars, then display text. Getting a stable picture was already satisfying, but Lode Runner made graphics unavoidable.
    The Apple II became the useful behavioral target. It had a software library I wanted and graphics simple enough to study at the circuit level. My design did not become a copied Apple II schematic; it became a different machine that reproduced enough behavior for selected software to run.
    Two problems made the video especially interesting. First, the CPU and video hardware share RAM. They must take turns on the bus, with the video path reading data and loading shift registers at the right time. Second, high-resolution Apple II graphics use seven displayed pixels per byte, while another bit changes the color behavior.
    The Apple II relies on NTSC artifact color. My output is VGA, so I needed logic to recreate that behavior rather than depend on a television decoder. A 4046 PLL was part of the experiments to produce the related pixel timing.
    The working result is why the video system is the part I am proudest of. A game moving on the monitor is also a demonstration that the clocking, memory access and output logic agree.
    These videos show experiments, including an intermediate GAL implementation. The later build replaced the 22V10 with discrete logic.
    Breadboard redesign:
    Color experiments and the plan:
    Language-card and banking work:
  • From software engineer to a bench full of wires
    Retrospective build log: the journey began in 2020. This entry collects the history for the 2026 project page; it is not backdated.
    I grew up with an Atari 1200XL and wanted to know how a box of chips could turn keystrokes into a game. Years later, working in software, I still wanted a more concrete answer.
    During 2020 I found Ben Eater's 6502 videos, bought the kit, and started building. Before that, I had never touched a breadboard or done hardware engineering. The first working circuit was not the end of the project; it was the invitation to add something else.
    Serial I/O and a monitor made the machine much more useful. I could inspect memory, load code and try ideas without treating every experiment as a complete rebuild. VGA, a keyboard, and software followed.
    The target that gave the project direction was Lode Runner. I did not know how I was going to get there, but I wanted to play a favorite game on a computer I had designed. That forced me to learn about both the software and the machine it expected.
    The practical lesson was to choose a goal I cared about, then work toward it in visible stages. A display signal, a keypress, a line of text and a running program each made the next problem less abstract.
    Build overview and early experiments:
    First breadboard community post:
    https://www.reddit.com/r/beneater/comments/ip871i/how_fast_can_you_run_your_breadboard_65c02/
    Starting point: https://eater.net/6502
View all 6 project logs
