Dynamic Zero
An open-source loudspeaker architecture using internally retained pneumatic energy to reinforce the incoming half-cycle.
0 followers
Dynamic Zero (DZ) is an experimental open-source loudspeaker architecture based on controlled reciprocal pneumatic interaction behind the driver diaphragm.
The internal pneumatic structure retains part of the state and energy from the preceding half-cycle and uses it in interaction with the incoming half-cycle.
Unlike bass-reflex systems, resonance is not the intended operating mechanism. Internal resonances are treated as parasitic conditions to be minimized.
The project is currently experimental. Prototype measurements, raw REW data, CAD files and build information are published openly for independent testing.
## How Dynamic Zero Works
Dynamic Zero uses the pneumatic state retained from the preceding half-cycle as part of the interaction that creates the new acoustic state.
The previous pneumatic state does not disappear when the next half-cycle begins. Pressure distribution and air-mass momentum remain physically present inside the DZ network and interact with the new driver input.
### MOPA Analogy
A useful conceptual analogy is a Master Oscillator Power Amplifier (MOPA). DZ is not an acoustic implementation of an optical MOPA; the analogy refers only to combining retained energy from a preceding state with new input energy.
In the ideal periodic T/2 case:
p(t-T/2) = -p(t)
After pneumatic inversion:
p(t) + [-p(t-T/2)] = 2p(t)
The ideal pressure ratio is therefore 2:1, corresponding to approximately +6 dB. This theoretical value cannot be achieved in a real DZ system due to unavoidable losses.
The important point is simple:
**The new input does not start from zero. It interacts with energy retained from the preceding state.**
DZ is not tuned by resonance. Internal resonances inevitably exist, but they are treated as parasitic conditions to be minimized rather than as the operating mechanism.
View all 2 project logs
