Caspian-BYOC: a paste-one-link travel router
Paste one proxy share link into a Raspberry Pi. It re-shares that tunnel as a WiFi hotspot, so every device in the room is covered, no app.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A Raspberry Pi 5, a USB WiFi adapter, and one pasted link. That is the whole build. What you get is a travel router that puts every device in a hotel room, a rented flat or a workshop behind one tunnel you control.
THE PROBLEM WITH PER-DEVICE CLIENTS
Most tunnelling setups ask every device to run a client. That falls over the moment a device cannot run one. A smart TV cannot. A games console cannot. A printer cannot. A relative's phone technically can, but you are not going to configure it, and you certainly are not going to reconfigure it every time something changes.
Caspian-BYOC moves the tunnel one hop out, onto the box. Configure once, on the box, and everything downstream is covered.
HOW IT WORKS
1. Install on a Raspberry Pi, or on a Windows PC, a Mac, or any Linux machine.
2. Open the web panel served by the box itself.
3. Paste a share link. It takes VLESS, VMess, Trojan, Shadowsocks, SOCKS and Hysteria2 links, Clash and Clash.Meta YAML, raw Xray JSON, link lis
