Yapunov log 4
A project log for EWNA Hackathon Team 6
YAPUNOV - You Are Protected Using Nonvisual, On-device Vigilance
supernicole0906superNicole0906 5 hours ago0 Comments
Detecting an emergency is important, but preventing an emergency before it happens can be even more valuable.
We therefore added a risk detection feature based on sound patterns over time. Instead of reacting to a single sound event, the system continuously monitors repeated environmental sounds.
For example, YAMNet can recognize water-related sounds such as dripping or running water. A single water drip is usually normal, but if the system continuously detects water sounds over a certain period of time, it may indicate a possible water leak.
The system can then generate an early warning before the situation develops into a more serious problem.
This adds a second layer of home safety:
Emergency detection → respond to danger
Risk prediction → identify potential danger early
