Wires, wires everywhere
A project log for Open (garage) Sesame!
Putting a garage door opener inside the dash of my car.
wjcarpenterWJCarpenter • 09/27/2026 at 00:31•0 Comments
Setting aside for the moment that I have no definitive wiring diagrams for this car, there are a few options for powering the remote. This is a subject area where I did a lot of iterative discussions with Gemini AI to try to figure out what is best.
Here are some of the things considered:
There is a small LED light that shines into the footwell area. You might have noticed it in the photo of the complete kick panel.
Here's the connector for that LED on the inside of the kickpanel. (The orange thing is just one of my pry tools, not part of the car stuff.)
There are 2 wires (blue and white), and it's a simple "dumb" LED powered by those wires. The LED is part of the courtesy light scheme that comes on when you unlock or open the driver door and that stays on for a little while after the car is turned off. That's a good type of power timing for using the remote control.
I tapped into that pair of wires with Posi-tap connectors and used my multimeter to sort out power and ground. After attaching the leads for the buck converter, I was able to operate the remote while not noticeably affecting the LED brightness.
(After completing everything and being "done" with the project, I had a moment of panic. I had only tested that LED power while sitting in the car in my garage. Why should that LED remain lit while I was actually driving around? It would be quite annoying to have to turn off the car to close the garage door after leaving or to open the garage door when returning home. I tested that the next day, and it turned out the good way. That LED was on the whole time. I think I just got lucky with a 50/50 choice made by the Nissan engineers.)
