Step 1: Managing Credentials Off-Chip
As with previous builds, authentication credentials remain isolated from the primary firmware logic in a local secrets.py file. Copy and paste the code below into a new code window, enter your own username and key, and save it as secrets.py on the MicroPython device.
# secrets.py
ADAFRUIT_IO_USERNAME = "your_username_here"
ADAFRUIT_IO_KEY = "your_aio_key_here"
This keeps personal API tokens off version control while allowing the main script to reference dynamic feed paths.
Step 2: The Firmware Breakdown
Let's dissect the implementation details and hardware considerations behind this autonomous edge controller.
1. Imports and Setpoint Configuration
import gc
import network
import time
from machine import I2C, SPI, Pin
import ahtx0
from umqtt.simple import MQTTClient
from secrets import ADAFRUIT_IO_KEY, ADAFRUIT_IO_USERNAME
# MQTT Broker Details
MQTT_HOST = "io.adafruit.com"
MQTT_PORT = 1883
TEMP_TOPIC = ADAFRUIT_IO_USERNAME + "/feeds/temperature"
HUMIDITY_TOPIC = ADAFRUIT_IO_USERNAME + "/feeds/humidity"
FAN_TOPIC = ADAFRUIT_IO_USERNAME + "/feeds/fan"
PUBLISH_INTERVAL_MS = 30000
# Temperature thresholds for fan control (Celsius)
TEMP_FAN_ON = 25.0
TEMP_FAN_OFF = 24.0 # Hysteresis band
Target Feeds: Three streams are prepared—temperature, humidity, and a dedicated fan feed to mirror the hardware's autonomous decisions back to our remote dashboard.
Hysteresis Logic: Turning a fan on and off at a single target (say, exactly 25.0°C) causes rapid relay or MOSFET chattering as the temperature hovers around the setpoint. Introducing a 1.0°C deadband (
TEMP_FAN_ON = 25.0andTEMP_FAN_OFF = 24.0) stabilizes mechanical and electrical components. You can change the numbers to whatever temperature you would like the fan to turn on and off at.
Quick Note:
Make sure you have the ahtx0 and MQTT client libraries installed. The MQTT client library can be installed by navigating to Tools -> Manage Packages and searching for micropython-umqtt.simple.
The ahtx0 library can be installed using the mip module. Once your board is connected to the internet (via your Ethernet setup), open the REPL and run:
import mip
mip.install("github:targetblank/micropython_ahtx0/blob/master/ahtx0.py")
2. Robust W5500 Bring-Up with Hardware Reset
# Configure SPI 2 for the internal W5500 controller spi = SPI(2, baudrate=8_000_000, polarity=0, phase=0) cs = Pin("PB12", Pin.OUT) rst = Pin("PD9", Pin.OUT) # Explicit hardware reset toggle rst.value(0) time.sleep_ms(10) rst.value(1) time.sleep_ms(200) nic = network.WIZNET5K(spi, cs, rst) nic.active(True) nic.ifconfig("dhcp") print("Waiting for DHCP...") deadline = time.ticks_add(time.ticks_ms(), 30000) while nic.ifconfig()[0] == "0.0.0.0": if time.ticks_diff(deadline, time.ticks_ms()) <= 0: raise RuntimeError("DHCP timeout") time.sleep_ms(500) # Verify physical link state timeout = 10 while not nic.isconnected() and timeout > 0: time.sleep(1) timeout -= 1 if nic.isconnected(): print("→ Ethernet Link UP!") print(" IP Address:", nic.ifconfig()[0]) else: print("→ Failed to detect physical link. Check cable and switch.")
Physical Reset: Toggling
PD9low for 10 ms before high-impedance initialization clears internal state registers on the W5500, guaranteeing a fresh start after soft reboots in MicroPython.Link State Polling: Beyond obtaining a DHCP lease, calling
nic.isconnected()checks whether physical Ethernet carrier pulses are detected before trying to initiate TCP transactions.
3. Peripherals: I2C Sensor and High-Power Actuator
# Initialize I2C bus and AHT20 sensor i2c = I2C(1) print("I2C devices:", i2c.scan()) sensor = ahtx0.AHT20(i2c) # Configure fan actuator output fan = Pin("PD13", Pin.OUT) # Connected to MOSFET TRIG/PWM pin fan.off()
- I2C Bus Init: I2C(1) scans the lines and latches the AHT20 at address 0x38.
- Actuator Isolation: Microcontroller GPIOs cannot drive DC fans directly without frying pins. PD13 is mapped to the gate of an external N-channel MOSFET module, isolated to switch an external 5V/12V rail. Driving it low on boot ensures the cooling element stays unpowered during initialization.
4. MQTT Connection
client_id = "w55mh32-mqtt"
client = MQTTClient(
client_id,
MQTT_HOST,
MQTT_PORT,
ADAFRUIT_IO_USERNAME,
ADAFRUIT_IO_KEY,
client.connect()
print("Connected to MQTT")
Unlike our earlier project, this client operates in an uplink-first telemetry mode. It does not subscribe to incoming actuator toggles; the device evaluates its environment locally and transmits status updates upstream.
5. Autonomous Control with Hysteresis
def update_fan_and_sensors():
temperature = round(sensor.temperature, 1)
humidity = round(sensor.relative_humidity, 1)
print("Temperature:", temperature, "C")
print("Humidity:", humidity, "%")
# Hysteresis fan logic
if temperature >= TEMP_FAN_ON and fan.value() == 0:
fan.on()
print(f"→ Fan turned ON (Temp >= {TEMP_FAN_ON}°C)")
try:
client.publish(FAN_TOPIC, "ON")
except Exception:
pass
elif temperature < TEMP_FAN_OFF and fan.value() == 1:
fan.off()
print(f"→ Fan turned OFF (Temp < {TEMP_FAN_OFF}°C)")
try:
client.publish(FAN_TOPIC, "OFF")
except Exception:
pass
# Publish environment feeds
client.publish(TEMP_TOPIC, str(temperature))
client.publish(HUMIDITY_TOPIC, str(humidity))
print("Sensor data published")
Local State Machine: Instead of trusting a cloud automation routine (which would fail if the internet dropped), the microcontroller compares local metrics directly against
TEMP_FAN_ONandTEMP_FAN_OFF.State Change Filtering: The fan state is published only when an actual transition occurs (
fan.value() == 0transitioning tofan.value() == 1), preserving network overhead and preventing unnecessary broker hits.Fault-Tolerant Publishing: Wrapping transient MQTT publishes in a
try/exceptguard prevents an intermittent socket hiccup from crashing the local thermal protection loop.
6. Periodic Execution Loop
last_publish = time.ticks_ms()
try:
while True:
now = time.ticks_ms()
if time.ticks_diff(now, last_publish) >= PUBLISH_INTERVAL_MS:
last_publish = now
gc.collect()
time.sleep_ms(100)
except KeyboardInterrupt:
print("Disconnecting...")
fan.off()
client.disconnect()
Non-Blocking Timer:
time.ticks_diff()tracks the 30-second window accurately without blocking execution, leaving room to add secondary loops or push-button overrides down the road.Safety Fallback: If execution is stopped manually via a
KeyboardInterruptin Thonny, the exception handler explicitly callsfan.off()so actuators aren't left running uncontrolled on pin state float.
The Result
Connecting the W55MH32L to an external MOSFET and configuring an Adafruit IO dashboard turns this into a fully functioning system. Below is a demonstration video.
Improvements
Something we can immediately notice from the video is that it takes quite a long time for the sensor to publish it's data before the fan turns on.
The code uses a 30-second repeating countdown timer. The problem was that instead of starting the timer after doing the first check, the program started the countdown timer first. Because the function was placed entirely inside that timer, the system was forced to wait 30 seconds before taking its very first reading.
One solution to fix this is to run it once immediately before entering the loop.
update_fan_and_sensors() last_publish = time.ticks_ms()
Jonathan
