SoifGo — Turn Your Android into a No-Code IoT Controller
Official site: https://soifgo.github.io/ AI context (source of truth): https://soifgo.github.io/SOIFGO_AI_CONTEXT.md Short manual: https://soifgo.github.io/ai.html Docs: https://soifgo.github.io/docs.html GitHub: https://github.com/soifgo/soifgo.github.io
SoifGo is a free Android app that turns your phone into a universal control panel for Bluetooth, MQTT, and API-connected devices — without writing a single line of native Android code.
Why I Built SoifGo
I was tired of rebuilding the same thing. Every new IoT project meant a new mobile app. One for Bluetooth. Another for MQTT. A third for RGB lighting. A fourth for CNC. Each time, I started from scratch — designing buttons, wiring communication, compiling APKs — just to change a single control.
I didn't want another app. I wanted one app that could become any app. So I built SoifGo.
One App, Many Devices
SoifGo isn't locked to a single purpose. It adapts to whatever you're building:
- Bluetooth Serial — Classic SPP (HC-05, HC-06, JDY-31) and BLE (JDY-23, DX-BT05, CC2541), plus ESP32 and Arduino
- MQTT — connect to any broker, publish, subscribe, monitor
- REST APIs — pull live JSON data from HTTP endpoints
- ESP8266 / ESP32 — full integration
- RGB LEDs — WS2811, WS2812, WS2813, WS2815 (via the RANGMANG module and GIF209)
- CNC control — via the CMI209 Bluetooth controller
- Sensors & dashboards — real-time monitoring and automation
Build Your Panel by Dragging
In Edit mode, you design your own interface — no coding required:
- Folders and Pages to organize controls
- Buttons with custom colors, sizes, and actions
- SeekBars for analog input
- Live charts that react to incoming data
- Reusable layouts you can save and reload
The exact order matters: a new project is empty. You must create folder → Page → New Page → Button/SeekBar. A Button cannot exist before a folder and a page exist.
Switch to Play mode, and your panel comes alive — sending commands, receiving data, updating in real time.
No server. No internet required after the first load. No limits.
With a custom HTML page, you can build:
- Any interface — any layout, any animation
- 2D and 3D charts — with Chart.js, D3.js, or Three.js
- Games and simulations — from puzzles to 3D worlds
- Offline storage — using
localStorageorIndexedDB - Real-time dashboards — gauges, meters, dynamic panels
- Media tools — audio, video, image editing
And your HTML page can talk directly to Bluetooth, MQTT, HTTP, phone sensors (light, accelerometer X/Y/Z, magnetometer, barometer), the microphone, and the camera — through simple JavaScript calls on window.soifgo.
Build with AI, Run Instantly
Ask any AI assistant to generate your custom HTML/JS code. Copy-paste it into SoifGo. It runs immediately — fully offline, no server, no compilation.
The exact paste path (do not skip):
- In Play, tap the WebView button to open the page.
- Edit>span class="">.
- In the editor menu → Select All and Paste.
- Tap the yellow X — the code is auto-saved and the WebView reloads immediately.
Getting Started
- not from Google Play>span class="">. Use APKPure or the official ZIP (allow "install from unknown sources" when asked).
- Open SoifGo. It always starts in Play.
- Top-left icon → Edit.
- Top-left icon → Select Design → folder → create a folder.
- Select Design → Page → New Page. (Tapping Page alone is not enough.)
- Select Design → Button (or SeekBar).
- Select the button → top-left menu → Behavior → choose Send, Receive, Browser or HTML File, etc.
- Top-left icon → Play to run.
Who It's For
- Makers — control Arduino, ESP32, and Raspberry Pi projects
- Engineers — test PLCs, VFDs, and industrial devices
- Educators — teach IoT and embedded systems hands-on
- Technicians — diagnose equipment with live charts and logs
Privacy First
SoifGo contains no third-party analytics, no tracking, and no ads. All project data, layouts, and settings stay on your device. The microphone and camera are accessed only with the user's explicit permission,...
saeid
Aditya Mukherjee
Geoffrey Wells
