11Close the case
Close the case, making sure to hold the keyboard while you're doing it and screw it shut. Now would be a good time to add those console key caps.
Congratulations, you're done! Turn your computer on and enjoy your mechanical keyboard. It's a good idea to go into BASIC and check every key works. There are also keyboard testers that will allow for a complete check.
Bertrand Le Roy
