PicoCRT
Using a classic Macintosh 1-bit monochrome analog CRT as monitor for a modern computer,
Public Chat
0 followers
I have a strong affinity for Classic Macintosh computers. When a Mac SE FDHD proved beyond repair, the analog board and CRT survived — and took on a life of their own.
Inspired by Spritemod’s work on interfacing a Macintosh CRT, I wanted to build a more generic video interface usable from Mac, PC and Linux alike. I settled on the Raspberry Pi Pico. The CRT requires three signals: H-sync, V-sync and data. The RP2040 handles all three simultaneously using its Programmable I/O state machines. A full frame is just 22 KB (512×342 pixels, 1 bit per pixel), well within the chip’s 264 KB SRAM — and it doubles as a USB device.
It works. On Linux it can be driven by a kernel module or from user space. A Python script pushes still images to the screen. A macOS proof-of-concept captures the screen, scales and dithers it to 1-bit monochrome, and streams it live to the display.
PicoCRT is a hardware/software project that drives the internal CRT of a Compact Macintosh (SE, Classic, Plus) using a Raspberry Pi Pico (RP2040), without the original Apple logic board.
The Compact Mac CRT requires three TTL-level signals: horizontal sync (HSYNC), vertical sync (VSYNC) and monochrome pixel data (DATA). The display runs at a fixed 512×342 resolution with a dot clock of 15.625 MHz, HSYNC at ~22.2 kHz and VSYNC at ~60 Hz. The pixel data is 1-bit monochrome with inverted polarity — high means black, low means white — and the electron beam must be blanked (data held high) outside the active video area, including during both horizontal and vertical retrace.
The RP2040’s Programmable I/O (PIO) subsystem makes this possible. Three PIO state machines run simultaneously and independently: one generates HSYNC with precise dot-clock timing, one generates VSYNC and counts scan lines, and one clocks out pixel data from a framebuffer in RAM. The state machines are synchronized via PIO interrupt flags rather than software, giving cycle-accurate timing without any CPU involvement. DMA transfers the framebuffer to the data state machine in a continuous loop, freeing the CPU entirely for application logic.
The framebuffer is 512×342 pixels at 1 bit per pixel  (21,888 bytes) - a small fraction of the RP2040’s 264 KB SRAM. Pixel data is packed MSB-first, with bit 31 representing the leftmost pixel in each word.
The RP2040’s GPIO outputs (3.3V) connect directly to the analog board without a level shifter. In practice the analog board’s TTL inputs trigger reliably at 3.3V, as confirmed by testing against both Mac SE - however I have not made it work on a otherwise identical Mac Classic display.
The Pico’s USB device capability enables a simple host-side protocol for pushing framebuffer content to the display. Current software includes a Python script for still images, a Linux kernel module, and a macOS proof-of-concept that captures the screen, scales it to 512×342 and dithers it to 1-bit monochrome using Floyd-Steinberg dithering before streaming it live to the CRT.
  • 1 × Raspberry Pi Pico (rp2040)
  • 1 × 4 wires
  • 1 × Analog board, CRT and power supply from a Mac SE or similar
  • 1
    Step 1
    The Mac SE and Mac Classic use different connectors on the analog board, the signals are the same, but this only works for SE
    All you will need is a RP2040 and four wires and a ground connection. Connect directly from the Pico’s GPIO pins to the analog board’s signal pins.
    Flash the Pico with the firmware and connect the wires as follows
    • GPIO18 -> DATA
    • GPIO19 -> VSYNC
    • GPIO21 -> HSYNC
    • GND -> GND
    The analog board must be powered independently — either inside a Compact Mac chassis with its original power supply, or via an ATX power supply providing +5V, +12V and −12V. Do not attempt to power the analog board from the Pico ;)
    Warning:The CRT operates at up to 15,000 volts at the anode. Always discharge the CRT before working inside the chassis, and treat all high-voltage areas with appropriate caution. If you have no idea what I'm talking about, please don't go on
    GitHub repo available soon
View all instructions
