#include <PWMServo.h>
#include <NewPing.h>
PWMServo servo1;
unsigned int duration;
long timer;
#define svomin 10
#define svomax 150
#define svodormant 80
#define lmotor 1
#define rmotor 2
#define mStop 0
#define mForward 1
#define mReverse 2
#define mLeft 3
#define mRight 4
#define lmotorf 3
#define lmotorr 2
#define rmotorf 5
#define rmotorr 4
#define trigPin 14
#define echoPin 15
#define button1 16
#define avoid 17
#define maxdistance 100
long runTime = 0;
int robotState = mStop;
int mbm = 52;
int svo = svomin;
int count = svomax - svomin;
float distance[180];
int buttonState;
int lastButtonState = LOW;
int scanState = false;
int avoidState;
int lastAvoidState = LOW;
long lastDebounceTime = 0;
long debounceDelay = 50;
NewPing sonar(trigPin, echoPin, maxdistance);
void setup() {
servo1.attach(SERVO_PIN_A);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(button1, INPUT);
pinMode(avoid, INPUT);
pinMode(lmotorf, OUTPUT);
pinMode(lmotorr, OUTPUT);
pinMode(rmotorf, OUTPUT);
pinMode(rmotorr, OUTPUT);
Serial.begin(57600);
svo = svodormant;
servo1.write(svo);
delay(1000);
timer = millis() + mbm;
scanState = false;
void loop() {
int reading = digitalRead(button1);
avoidState = digitalRead(avoid);
if (scanState == true) {
robotStop();
if (avoidState == LOW && scanState == false && robotState == mForward) {
scanState = true;
svo = svomin;
servo1.write(svo);
if (reading != lastButtonState) {
lastDebounceTime = millis();
if((millis() - lastDebounceTime) > debounceDelay) {
if(reading != buttonState) {
buttonState = reading;
if(buttonState == HIGH) {
scanState = true;
svo = svomin;
servo1.write(svo);
lastButtonState = reading;
if(timer < millis() && scanState==true) {
getDist2();
svo++;
if(svo > svomax) {
svo=svodormant;
smooth();
smooth();
Serial.println("");
Serial.println("BEGIN");
for(int i=0;i<=count;i++) {
Serial.print("S");
Serial.println(i+10,DEC);
Serial.print("V");
Serial.println(distance[i], DEC);
scanState = false;
robotThink();
servo1.write(svo);
if(svo==svomin) { delay(1000); }
if (runTime < millis()) {
motor(lmotor, mStop);
motor(rmotor, mStop);
robotThink();
void getDist2() {
duration = sonar.ping();
distance[svo-svomin] = duration/US_ROUNDTRIP_CM;
if(duration==0) { distance[svo-svomin] = maxdistance; }
void smooth() {
int p;
float temp;
float mean;
mean=0;
for(int t=-4;t<=4;t++) {
p=i+t;
if(p>count) {
p=p-(count+1);
if(p<0) {
p=p+(count+1);
mean = mean + distance[p];
mean = mean / 9;
distance[i] = mean;
void motor(int m, int d) {
int mf;
int mr;
switch (m) {
case lmotor:
mf = lmotorf;
mr = lmotorr;
break;
case rmotor:
mf = rmotorf;
mr = rmotorr;
break;
default:
mf = 0;
mr = 0;
switch (d) {
case mStop:
digitalWrite(mf, LOW);
digitalWrite(mr, LOW);
break;
case mForward:
digitalWrite(mf, HIGH);
break;
case mReverse:
digitalWrite(mr, HIGH);
break;
default:
void robotStop() {
runTime = 1000;
robotState = mStop;
void robotForward() {
motor(lmotor, mForward);
motor(rmotor, mForward);
runTime = 1000;
robotState = mForward;
void robotReverse() {
motor(lmotor, mReverse);
motor(rmotor, mReverse);
runTime = 1000;
robotState = mReverse;
void robotLeft() {
runTime = 1000;
robotState = mLeft;
void robotRight() {
runTime = 1000;
robotState = mRight;
void robotThink() {
if (avoidState == HIGH && scanState == false) {
robotForward();
if (avoidState == LOW && scanState == false) {
robotRight();
if (avoidState == LOW && scanState == true) {
robotStop();
