//Rangefinder Arduino code
//Ultrasonic Rangefinder
#include <PWMServo.h>
#include <NewPing.h>
PWMServo servo1;
unsigned int duration;
long timer;
#define svomin 10
#define svomax 150
#define svodormant 80
#define lmotor 1
#define rmotor 2
#define mStop 0
#define mForward 1
#define mReverse 2
#define mLeft 3
#define mRight 4
#define lmotorf 3
#define lmotorr 2
#define rmotorf 5
#define rmotorr 4
#define trigPin 14
#define echoPin 15
#define button1 16
#define avoid 17
#define maxdistance 100
long runTime = 0;
int robotState = mStop;
int mbm = 52;
int svo = svomin;
int count = svomax - svomin;
float distance[180];
int buttonState;
int lastButtonState = LOW;
int scanState = false;
int avoidState;
int lastAvoidState = LOW;
long lastDebounceTime = 0;
long debounceDelay = 50;
NewPing sonar(trigPin, echoPin, maxdistance);
void setup() {
servo1.attach(SERVO_PIN_A);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(button1, INPUT);
pinMode(avoid, INPUT);
pinMode(lmotorf, OUTPUT);
pinMode(lmotorr, OUTPUT);
pinMode(rmotorf, OUTPUT);
pinMode(rmotorr, OUTPUT);
Serial.begin(57600);
//Serial.print("AT+BAUD7");
svo = svodormant;
servo1.write(svo);
delay(1000);
timer = millis() + mbm;
scanState = false;
void loop() {
int reading = digitalRead(button1);
avoidState = digitalRead(avoid);
if (scanState == true) {
robotStop();
if (avoidState == LOW && scanState == false && robotState == mForward) {
scanState = true;
svo = svomin;
servo1.write(svo);
if (reading != lastButtonState) {
lastDebounceTime = millis();
if((millis() - lastDebounceTime) > debounceDelay) {
if(reading != buttonState) {
buttonState = reading;
if(buttonState == HIGH) {
scanState = true;
svo = svomin;
servo1.write(svo);
lastButtonState = reading;
if(timer < millis() && scanState==true) {
getDist2();
svo++;
if(svo > svomax) {
svo=svodormant;
smooth();
smooth();
Serial.println("");
Serial.println("BEGIN");
for(int i=0;i<=count;i++) {
Serial.print("S");
Serial.println(i+10,DEC);
Serial.print("V");
Serial.println(distance[i], DEC);
scanState = false;
robotThink();
servo1.write(svo);
if(svo==svomin) { delay(1000); }
if (runTime < millis()) {
motor(lmotor, mStop);
motor(rmotor, mStop);
robotThink();
void getDist2() {
duration = sonar.ping();
distance[svo-svomin] = duration/US_ROUNDTRIP_CM;
if(duration==0) { distance[svo-svomin] = maxdistance; }
void smooth() {
int p;
float temp;
float mean;
mean=0;
for(int t=-4;t<=4;t++) {
p=i+t;
if(p>count) {
p=p-(count+1);
if(p<0) {
p=p+(count+1);
mean = mean + distance[p];
mean = mean / 9;
distance[i] = mean;
void motor(int m, int d) {
int mf;
int mr;
switch (m) {
case lmotor:
mf = lmotorf;
mr = lmotorr;
break;
case rmotor:
mf = rmotorf;
mr = rmotorr;
break;
default:
mf = 0;
mr = 0;
switch (d) {
case mStop:
digitalWrite(mf, LOW);
digitalWrite(mr, LOW);
break;
case mForward:
digitalWrite(mf, HIGH);
break;
case mReverse:
digitalWrite(mr, HIGH);
break;
default:
void robotStop() {
runTime = 1000;
robotState = mStop;
void robotForward() {
motor(lmotor, mForward);
motor(rmotor, mForward);
runTime = 1000;
robotState = mForward;
void robotReverse() {
motor(lmotor, mReverse);
motor(rmotor, mReverse);
runTime = 1000;
robotState = mReverse;
void robotLeft() {
runTime = 1000;
robotState = mLeft;
void robotRight() {
runTime = 1000;
robotState = mRight;
void robotThink() {
if (avoidState == HIGH && scanState == false) {
robotForward();
if (avoidState == LOW && scanState == false) {
robotRight();
if (avoidState == LOW && scanState...
sad_ken
GOAT INDUSTRIES
tehaxor69
Makerfabs
DamianDurczok
Hello dude, are you still working on this project? 'Cause i've problem with my project. I'am working on arduino based sonar with stepper motor and hc-sr04 ultrasonic sensor, i wrote the codes on arduino and i am trying to processing radar screen on MatLab but it doesn't work. After 5-10 degree scanning, the scanner bar is missing every time. Can you send me your arduino codes for this project?
