RealisticPM is an open-source, wall-mounted room air quality monitor focused on PM2.5 (fine particulate matter). It is powered over USB-C and built around the Seeeduino XIAO SAMD21, a small ARM Cortex-M0+ microcontroller board.
Features:
- Big color display
- Standard USB-C connector
- Low power consumption (2 W max)
- High-quality LEDs
- Data output over a virtual COM port
- Pin-out for development
- Open-source code
- Automatic brightness control
- Automatic color control via addressable LEDs
- Protected by a resettable fuse
- PM2.5 readings in steps as fine as 0.1 µg/m³
- Size of 364 × 164 x 18 mm, suited to workspaces, sport rooms, and clean rooms
pcadic
Stephen Gata
Chris Tully
