Pixlpal - Interactive AIoT Display
Pixlpal is a smart AIoT desktop companion with an interactive LED display based on the ESP32-S3
PIXLPAL is a smart AIoT desktop companion with an interactive LED display. It delivers real-time information—such as time, calendar events, weather, stocks/crypto tickers and sports updates—and offers features like AI-powered conversational assistant, HiFi audio playback from USB flash drives, and internet audio streaming.
Featuring a 128x64 RGB LED Panel (2mm pitch) and an ESP32-S3 SoC, the Pixlpal is completely hackable and extensible via it's USB-OTG interface/peripheral.
How it works
The Pixlpal-M1 firmware is built on the ESP-IDF framework, combining ESP-IDF components, Arduino libraries, and custom applications for the ESP32-S3 SoC.
Pixlpal fetches relevant information from the internet and shows it to users. Using the Pixlpal mobile app (iOS and Android), users can select and customise the device to display their preferred apps — such as clock, calendar, weather updates, stock/crypto tickers, ChatGPT conversational assistant, live sports updates, or internet radio.
The Pixlpal AIoT display also includes:
  • An embedded microphone for audio input.
  • A 3.5 mm audio jack for audio output to external speakers.
  • A multifunctional rotary encoder for manual control — allowing brightness adjustment, volume control, parameter changes, and more.
New apps and features are delivered via Over-The-Air (OTA) updates. Through the USB-OTG interface, Pixlpal can be expanded with USB peripherals such as cameras, mice, keyboards, flash drives, and speakers for added functionality.
Each application runs as a standalone FreeRTOS task and can be launched via BLE commands from the Pixlpal Android or iOS mobile app.
Key Features
  • Modular Application Framework – Built on FreeRTOS tasks for easy expansion.
  • ESP32-S3 Target – Optimized for neural network acceleration and signal processing.
  • Flexible Library Integration – Supports any Arduino library or ESP-IDF component.
  • Rich Graphics Capabilities – Draw text, shapes, GIF, PNG, and SVG images.
  • Connectivity – Wi-Fi for internet access, BLE for remote control and configuration.
  • Audio Processing – Microphone input and DAC audio output via I2S (ESP32-audioI2S by schreibfaul1).
  • USB-OTG/CDC – Read/write USB flash drives.
  • Dual OTA Update Modes:
    1. From GitHub releases
    2. From USB flash drive (offline)
  • Rotary Encoder Control – Multi-functional input (ebtn by saawsm).
  • MQTT Support – Integrated via the PicoMQTT library by Mlesniew.
Electronic schematic of the Pixlpal control board featuring the ESP32-S3 SoC Module
Portable Network Graphics (PNG) - 524.77 kB - 08/26/2025 at 19:30
Preview
  • 1 × ESP32-S3 N16R8 SoC Module Microcontroller featuring Wi-Fi and BLE for data processing and display driver
  • 1 × PCM5102A Audio DAC Module Audio processor chip using the I2S communication interface
  • 1 × INMP441 MEMS Microphone Module Microphone module
  • 1 × P2 RGB LED Display Module 256*128mm (128x64 SMD1515 LEDs) LED Matrix Display Module
  • 1 × 15mm Half Axis Rotary Encoder (EC11) Multi-Functional Rotary Encoder
View all 10 components
  • Pixlpal Firmware is Open Source
    Stephen Gata • 08/26/2025 at 20:52 • 0 comments
    Greetings,
    After years of isolated development, I'm pleased to present the Pixlpal Firmware as an Open Source Project.
    The project is quite matured, however, a lot still needs to be done. I hereby call on all embedded systems and IoT enthusiasts to freely tinker with the firmware source code, and suggest improvements where necessary. Please find the source code at: https://github.com/Meterbit/PIXLPAL-M1
View project log
View all instructions
Stephen Gata wrote 02/25/2026 at 14:14 • point
We’re excited to officially announce that the Pixlpal AIoT Display has launched on Crowd Supply!
Pixlpal is now live on the crowdfunding platform, and you can support the project by becoming a backer. If you’d like to be part of this journey and help bring Pixlpal to more homes, workspaces, and maker communities, simply visit the campaign page here:
👉 https://www.crowdsupply.com/meterbit-cybernetics/pixlpal
Thank you for your support and for being part of the Pixlpal story! 🚀
Stephen Gata wrote 10/22/2025 at 13:41 • point
Hello Friends and Followers of Pixlpal,
We hope you’re having a great week!
We at Meterbit Cybernetics — the creators of the Pixlpal AIoT Smart Display — are thrilled to announce our partnership with Crowd Supply.
This partnership gives us the opportunity to make Pixlpal available to users around the world through a trusted crowdfunding platform known for delivering on its promises to backers.
You can now check out the Pixlpal Pre-launch Page here:
If you have any questions about the device or the pre-launch process, feel free to reach out — we’d love to hear from you.
Thanks for being part of the Pixlpal journey!
— The Meterbit Cybernetics Team
