Mini Rotary Encoder + Push Button: Two Revisions
A compact rotary-encoder family with a momentary push switch and standard or castellated breakout layouts.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A rotary encoder and momentary push switch share one compact control, so turning can adjust a value and pressing can select it. This project covers both the original breakout and its revised connection layout.
The newer board adds hybrid castellated pads on a 2.54mm pitch. It can be soldered directly onto another PCB to avoid tall headers, while retaining the option of standard headers for prototyping. Both versions combine incremental rotation input with a push button.
Product: https://www.questwiseventures.com/products/mini-rotary-encoder-push-button-castellated-pins
