Week by Week
4 hours ago • 0 commentsWeek 1 — Requirements and feasibility.
We tested the VL53L1X against a real basketball to check detection reliability. Early results were noisy; we tightened the field of view with a 3D printed baffle and got clean readings.
Week 2 — Schematic and first PCB.
Drew the schematic in KiCad, laid out a 4-layer board with a solid ground plane. Sent to JLCPCB for a five-piece run.
Week 3 — Firmware skeleton.
Got Zephyr running on the dev kit, brought up the RTC and I2S audio. Confirmed the alarm tone played at the target volume.
Week 4 — Sensor integration.
Wired the VL53L1X over I2C, wrote the detection state machine, tuned thresholds with real shots. Hit 97% detection accuracy across 200 test shots — misses were mostly soft layups that barely crossed the zone.
Week 5 — PCB assembly and bring-up.
Boards arrived, assembled one by hand. Found a footprint error on the RTC — fixed with a rework and a revised layout.
Week 6 — Enclosure and integration.
Printed the enclosure, mounted the sensor and speaker, ran the full system on battery. Got 23 days of standby on a single charge with the alarm firing once daily.
Week 7 — Field testing and polish.
Gave it to the client for two weeks of real use. He missed two alarms in that time, both on purpose to test the volume ramp.
Himanshu Dada
