Portable USB-C Power Monitor and Tester
I’m working on a small USB-C power monitoring device that can help makers understand how much power their electronic devices are drawing
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I’m working on a small USB-C power monitoring device that can help makers understand how much power their electronic devices are drawing during charging and operation. The idea is to build a compact tester that measures voltage, current, and power consumption in real time, making it easier to troubleshoot charging problems and test different USB-powered projects.
I want to make the device simple enough for hobbyists to build at home while still providing useful information for electronics experiments. The readings could be displayed on a small screen, allowing users to check whether a device is receiving stable power without needing a separate multimeter for every test.
Key Features
Voltage Measurement: Monitors the voltage supplied through a USB connection.
Current Monitoring: Measures the current drawn by a connected device.
Power Calculation: Calculates power consumption in watts using voltage and current readings.
Live Display: Shows measurements on a compact OLED
