I want to use Padauk, but I want to try out a new lighting scheme.
This is the initial test of using 3 LEDs. The issue with a single LED is that it is sometimes hard to sense the transition between states. With these three LEDs it should be much easier to follow along, but the question I have is that if it is intuitive, because with the Single LED, all you have to do is match the LED, but here you are actually counting the LEDs.
I'm also experimenting with different colors to represent different states.
