I experimented with a few potential focus images, and the one that I liked best is this:
Each quadrant represents what to do and it is very soothing for the eye to go in a circle. Before this I also tried it being a line and a sine wave that bounced back and forth, but those did not really work out. However I have high hopes for this particular design, especially since the LEDs are a bit clearer about when to move through each stage.
Also added a keychain hole that was missing from earlier editions. However, this means that the BreatheDot 2 is larger ~ 32mm across.
