Hello! This is quite an unexpected piece of good news. This project was chosen as one of the top twenty for the Hackaday Design Your Concept Entry! Thank you all for your support and comments.
Moving forward there are a few changes that I want to explore, adding a graphic for people who like the PCB as it is, and switching out the LED for a WS2812b or a Neopixel. This will test the battery life however, and it remains to be seen what the current draw will be. I have been able to successfully power 10 neopixels off 2 CR2032 batteries over an hour of usage, so this might be a promising avenue to look down.
