I wrote up a list of instructions in order to program the Attiny. It is set up in such a way that reprogramming will be easy.
I have tested the instructions and they should work smoothly. This was done in a Linux system, but you can subsitute the commands for those of a Windows system if you are using it to program the ATTiny85.
Ben Lim
