1Get a supported tag
pin16 targets Solum ESL tags built on the Silicon Labs EFR32BG22C224F512IM40 with 512 KB external SPI flash, an NFC chip, and a CR2450 coin cell. Panels supported: EL016F5W4C, EL016F6W4A (200x200) and EL022F5C4C (296x160, scanned as 160x296). Other tags on the same board report themselves over Bluetooth but aren't usable until their panel driver is added.
2Check the lock state
Factory tags ship with a locked EFR32BG22. Unlocking it over SWD erases the factory firmware for good, with no way to back it up, and leaves the tag with no bootloader afterward. There's no undo here, so treat this step as one-way before starting.
3Wire up SWD
Connect an SWD programmer to the tag. Pin mapping for the panel, NFC, and debug lines is in
docs/in the repo. -
4First flash (factory tag)
Flash the all-in-one image
SOLUM_BTL_FULL_vN.s37(bootloader plus firmware) over SWD. Full step-by-step is indocs/USER_GUIDE.md, under "First install on a factory tag." -
5Open the control page
The page lives in
docs/(index.htmlplus service worker and manifest) and talks to the tag over Web Bluetooth, no app needed. It works in English and Russian and installs offline as a PWA. -
6Pair and load content
Tap the tag's NFC to open its connection window (open for 60 seconds after the tap for anything sensitive), connect from the page, and upload images, set up the slideshow, or configure the BTHome beacon.
7Later updates
Once the tag runs pin16 with a bootloader, update it over Bluetooth from the page's "Firmware update" card using
pin16_vN.ota.bin. No SWD needed again, unless you're recovering a tag that has a bootloader but needs a freshfirmware.s37flashed at address 0x6000.
Siarhei Besarab
