This is one of the first hardware modules I designed and built myself: a 4-bit ALU made entirely from 74HC logic gates and multiplexers.
I wanted to build an ALU from scratch, understand how it works, and have something physical I could experiment with. And honestly, it sounded like a fun project!
"Isn't this reinventing the wheel? Integrated ALUs already exist!" Well, yes! But that wasn't the point. I wanted to build one myself and share it with others who might enjoy learning how an ALU works beyond what's shown in a datasheet.
It supports five operations: ADD, SUB, NAND, XOR, and NOR, with Carry, Zero, and Equal flags. This ALU is also one of the building blocks of my own 4-bit homebrew computer, which I'm building one module at a time.
Feel free to explore, rebuild, modify, or use it as inspiration for your own projects. The schematics, KiCad files, and documentation are available in the GitHub repository.
Files
Hardware-Minimalist 4-bit ALU (Modified 3-bit OP Code).zip
KiCad project, here you will find the schematic and the PCB design.
x-zip-compressed -
308.54 kB -
11/27/2026 at 03:49
