Noora UPS – One Programmable UPS for Every SBC
0.8–21 V programmable output. Up to 6.3 A. For Raspberry Pi, Orange Pi, NVIDIA Jetson, robotics, custom electronics and power banks.
Public Chat
0 followers
Noora UPS is a universal, programmable, and scalable UPS featuring a 0.8–21 V output, up to 6.3 A, and a target power of 132 W. It supports 1S–4S lithium-ion batteries, advanced Impedance Track™ fuel gauging, comprehensive battery protection, and cell balancing up to 100 mA. Multiple boards can be connected in parallel using our custom-designed current-sharing board.
One board for Raspberry Pi, Orange Pi, NVIDIA Jetson, robotics, custom electronics, and DIY power banks — eliminating the need for separate application-specific UPS and BMS boards.
Project Overview
Noora UPS is a universal, programmable, and scalable uninterruptible power supply designed to eliminate the need for application-specific UPS and battery management boards.
With a programmable output voltage ranging from 0.8 to 21 V, an output current of up to 6.3 A, and a target output power of up to 132 W, Noora UPS provides a flexible power platform for a wide range of applications.
Advanced Battery Management
Each Noora UPS board is designed to operate with one, two, three, or four series-connected lithium-ion cells (1S–4S), providing flexibility in battery configuration.
It incorporates advanced Impedance Track™ fuel gauging for accurate state-of-charge (SoC) and state-of-health (SoH) estimation, along with individual cell balancing at up to 100 mA.
The integrated battery management system (BMS) is designed to provide comprehensive protection against overcharging, over-discharging, cell overvoltage, undervoltage, overcurrent, short circuits, overtemperature, undertemperature, and charging timeouts.
Modular and Scalable Architecture
For applications requiring higher output current and power, multiple Noora UPS boards can be connected in parallel using our custom-designed current-sharing board.
This modular architecture allows users to scale the system according to their power requirements rather than being limited to the capabilities of a single board.
Design Objectives
Battery Management and Protection
  • Flexible and modular 1S–4S battery architecture
  • Accurate battery state-of-charge and state-of-health estimation
  • Configurable battery charging and discharging parameters
  • Individual series-cell voltage monitoring and battery temperature monitoring
  • Cell balancing up to 100 mA
  • Comprehensive battery and system protection
Power Management and System Reliability
  • Programmable output voltage
  • Scalable output current and power through parallel operation
  • Seamless transitions between external power and battery power
  • Low-battery reboot loop prevention
  • Hardware watchdog and automatic system recovery
  • Safe shutdown and controlled restart
  • Automatic restart after power restoration
Intelligent Control and Monitoring
  • RTC-based power scheduling
  • Real-time battery and power monitoring
  • System event and power interruption logging
One Board, Multiple Applications
Why buy a separate UPS HAT for your Raspberry Pi, another for your Orange Pi, and a dedicated BMS for your DIY power bank?
With Noora UPS, the same programmable board is designed to serve as a UPS for your Raspberry Pi, Orange Pi, NVIDIA Jetson Nano, or Jetson Orin Nano Super, power your robotics projects, provide uninterrupted power to custom electronics, or become the heart of your next DIY power bank.
Our goal is to develop a single, adaptable power platform that meets the requirements of different projects, rather than requiring a different power solution for every application.
One programmable UPS. Every SBC. Beyond SBCs.
For more information and to follow the Noora UPS crowdfunding campaign, visit our official Kickstarter project page:
https://www.kickstarter.com/projects/noora-solutions/ups-hat
  • 1 × BQ25750 Stand-alone or I²C-controlled 70-V bidirectional buck-boost charge controller with power path
  • 1 × BQ40Z50-R2 1-4 series Li-ion battery pack manager supporting Turbo Mode 2.0
  • 1 × TPS55288 36V, buck-boost converter with PPS control
  • How It All Started: From a Raspberry Pi UPS HAT to a Universal Programmable UPS
    Alireza Noferesti • an hour ago • 0 comments
    Like many engineering projects, Noora UPS started with a problem we needed to solve for one of our own products.
    At Noora Lab Tech, we were developing a Raspberry Pi-based industrial data logger that required a reliable uninterruptible power supply. Our goal was not simply to keep the Raspberry Pi running during a power outage, but also to ensure continuous data logging, reliable battery monitoring, safe shutdown, and automatic system recovery when external power was restored.
    We evaluated several commercially available UPS HATs. However, none fully met our expectations in terms of accuracy, reliability, battery management, power delivery, and overall engineering quality. We also encountered issues such as low-battery reboot loops and unstable power recovery after deep battery discharge.
    So, we decided to design our own UPS.
    From a Raspberry Pi HAT to Something Much Bigger
    Initially, our objective was to develop a high-quality UPS HAT specifically for the Raspberry Pi. However, as we progressed through component selection, power architecture design, and battery management research, we began asking ourselves a more fundamental question:
    Why limit a well-engineered UPS to just one single-board computer?
    Why should developers need a different UPS board every time they switch to a different SBC or start a new project?
    By selecting high-performance power management and battery management ICs from Texas Instruments, we realised that we could develop a much more capable and versatile platform.
    Instead of designing another fixed 5 V UPS HAT, we shifted our focus towards a fully programmable UPS with an adjustable output voltage from 0.8 to 21 V, an output current of up to 6.3 A, and a target output power of up to 132 W.
    We also wanted to go beyond conventional UPS designs by incorporating advanced Impedance Track™ fuel gauging, flexible 1S–4S battery configurations, comprehensive battery protection, cell balancing, and a modular architecture that allows multiple UPS boards to operate in parallel using our custom-designed current-sharing board.
    Beyond Single-Board Computers
    What started as a solution for our industrial data logger has now evolved into a much more ambitious engineering project.
    The same board could serve as a UPS for a Raspberry Pi, power an Orange Pi or NVIDIA Jetson Orin Nano Super, support a mobile robot, provide backup power for custom electronics, or even become the heart of a high-performance DIY power bank.
    Rather than designing a dedicated power solution for every application, we want to create a single programmable platform that adapts to the application.
    That is the philosophy behind Noora UPS.
    In our upcoming project logs, we will share our engineering decisions, component selection, power architecture, battery management design, development challenges, and prototype testing as the project progresses.
    You can also follow the project through our Kickstarter campaign:
View project log
