where it's at: from 1.0 to 1.0.7 in one week
2 hours ago • 0 commentsesp32-os went public about a week ago, and since then it got seven updates. a quick summary of what changed:
- stability: memory leaks fixed (the start menu leaked about 1 mb per hour), quake and home button crashes fixed, and when system memory is almost full it now refuses new programs instead of crashing
- new heap: free blocks live in an address-sorted tree instead of a long list, which removed a 41 second browser freeze on heavy sites
- browser: better css (var, calc, rgb, logical properties), more js apis, and a status bar that tells you when a page is loading, too large or out of javascript memory
- new stuff: weather app, ogg playback, and an app store that installs doom and quake over wi-fi with a sha-256 check
- polish: on-screen keyboard no longer loses taps when typing fast, a random light blue flash and 7 other visual glitches are gone, and the ui texts follow the language setting with english as default
every release runs a 75 minute endurance test with all apps, the last ones with 0 crashes and 0 reboots.
next up: getting more of the bigger websites to load, and support for a second board (the guition jc4880p443c) thanks to a community pull request.
you can try it from the browser: https://theunkn0wnc0de.github.io/ESP32-OS/
theunkn0wnc0de
