AWS IoT Button
04/07/2017 at 12:55 • 0 commentsIntegrated an Amazon AWS IoT Button
Firebase Realtime Database
03/29/2017 at 14:49 • 0 commentsHow do you design a system that authenticates different types of users without having users logged into the system? This was one of the more challenging aspects of the project. I decided on using Access Keys with unique id's to identify and connect users to cards, pins, locations, etc. Everything is stored in Firebase as lookups.
- Access Keys
- ID
- Name
- Type (admin, user, temp)
- Location (lookup)
- Expiration Date
- Deleted
- Registered
- Enable
- Location
- ID
- Name
- Mode (used for provisioning cards)
- Pins
- ID
- Access Key (lookup)
- Location (lookup)
- PIN
- Cards
- ID
- Location (lookup)
- Card Number
- Doors
- ID
- Location (lookup)
- Logs
- ID
- Location (lookup)
- PIN or Card or Door
- Access Keys
Mobile App Features List v1
03/29/2017 at 14:38 • 0 commentsThe Access Control System comes with an Android app used to manage access keys, create pins, provision cards, select boom music, open the door and more.
Admin: Usually the owner(s) of the company.
- Has the ability to create new Access Keys for their specified location.
- Can provision new cards for their specified location and attach them to a different Access Key (of same location)
- Can provision new pin for their specified location and attach them to a different Access Key (of same location)
- Can provision new temp pin for their location (creates an Access Key of type ‘temp’)
- Can enable/disable Access Keys for their location
- Can create their own pin
- Can provision their own card
- Can apply boom music
- Can view logs
- Can open door
User: Usually the employees of the company
- Can create new pin for their location
- Can open door
Temp: Used for pins (and card?) only
- Has an expiration date and time
- Set by the Admin
Austin Nelson
