Display prototype screwed to safety glasses
06/23/2017 at 10:03 • 2 commentsToday I screwed the first optical display to the safety glasses. I need to change a few little thinks to make the adjustment easier.
Modified design
06/23/2017 at 08:53 • 3 commentsPerfect over night print for the modified optical part. YAY
Ok, it works perfect
05/09/2017 at 18:01 • 4 commentsA few small modifications and it will work perfectly. The picture focuses exactly so that the image is clear and sharp. As reflector inside I used a small pieces of a cd box.
First printed parts
05/07/2017 at 09:52 • 0 commentsToday I found the time to attach the first printed parts to the safety glasses.
looks good and the first test were successful.
Concept II. Pic over a reflector
05/01/2017 at 20:13 • 2 commentsDesigning the housing for the concept II HMD.
Testing the mirrorless concept
04/23/2017 at 17:38 • 0 commentsToday I made the first optic test with a cardboard construction. It's the mirrorless version.
Works great and has definite potential.![]()
0.49 inch display ... online
04/19/2017 at 18:10 • 1 commentToday I found the time to connect the 0.49 inch, I2c display to the Arduino. I used the u8glib. The display is not in the list but this one works fine:
U8GLIB_SSD1306_64X48 u8g(U8G_I2C_OPT_NONE)
Now that the display is connected, I will play around with the U8Glib. The first Bitmap works:)
2 HMD Concepts
04/14/2017 at 12:46 • 0 commentsI'm trying 2 head mounted display concepts. One works with a Lens with an focal length of 45mm and a reflective surface. The other one is a Lens with an focal length of 15mm and a direct view.
Both are working fine with the first tests I've done.
New Parts and Test setup
04/12/2017 at 17:37 • 0 commentsHere are the safety glasses from 3M, I just bought today and the first setup with the 45mm lens
First Parts
04/05/2017 at 08:54 • 0 commentsThe first parts are here. For the tests, that's all I will need.
Alain Mauer
