1Step 1
RASPBIAN SETUP
To get started with Raspberry Pi one requires an operating system. RASPBIAN is an easy operating system install manager for the Raspberry Pi.
HOW TO GET AND INSTALL RASPBIAN
Step 1: DOWNLOAD
- Using a computer with an SD card reader, visit the Downloads page.
- Click on the Download ZIP button under ‘RASPBIAN (offline and network install)’, and select a folder to save it to.
- Extract the files from the zip.
Step 2: FORMAT YOUR SD CARD
It is best to format your SD card before copying the RASPBIAN files onto it. To do this:
- Visit the SD Association’s website and download SD Formatter 4.0 for either Windows or Mac.
- Follow the instructions to install the software.
- Insert your SD card into the computer or laptop’s SD card reader and make a note of the drive letter allocated to it, e.g. G:/
- In SD Formatter, select the drive letter for your SD card and format it.
Step 3: DRAG AND DROP RASPBIAN FILES
- Once your SD card has been formatted, drag all the files in the extracted RASPBIAN folder and drop them onto the SD card drive.
- The necessary files will then be transferred to your SD card.
- When this process has finished, safely remove the SD card and insert it into your Raspberry Pi.
Step 4: FIRST BOOT
- Plug in your keyboard, mouse and monitor cables.
- Now plug in the USB power cable to your Pi.
- Your Raspberry Pi will boot, and a window will appear with a list of different operating systems that you can install. We recommend that you use Raspbian – tick the box next to Raspbian and click on Install.
- Raspbian will then run through its installation process. Note this can take a while.
- When the install process has completed, the Raspberry Pi configuration menu (raspi-config) will load. Here you are able to set the time and date for your region and enable a Raspberry Pi camera board, or even create users. You can exit this menu by using Tab on your keyboard to move to Finish.
Step 5: LOGGING IN AND ACCESSING THE GRAPHICAL USER INTERFACE
The default login for Raspbian is username pi with the password raspberry. Note you will not see any writing appear when you type the password. This is a security feature in Linux.
To load the graphical user interface type startx.
We can use the SSH protocol to access the raspberry terminal from any system. We can enable SSH in the raspberry pi by using the command,
sudo raspi-config
Enable or disable ssh server
We can use putty for the remote interaction and also we can access the GUI of the LXDE desktop by enabling X11 forwarding and then we have to start the XMING. Now start putty where we enter the remote IP to start the session which will ask for the user name and password. After that the remote shell terminal will be opened. To access the GUI we have to use the command,
Sudo startlxde
Once the terminal is started, we can entirely control the raspberry pi using the putty. It is only possible in the internal network. But if we need to access the raspberry pi from the external network then we have to enable the port forwarding so that we can access it from anywhere.
FIGURE 4.1.1 Port forwarding block diagram
4.2 PUTTY WINDOW
FIGURE 4.2.1 Putty window
PUTTY is a light weight plug and play software which can be used to control shell using various protocols like ssh, serial, telnet, raw and rlogin. The communication between the end node and the computer will be encrypted using an ssh key. It uses an AES encryption standard. This is capable of working under a proxy protocols like http, https, socks4, socks5, squid.
2Step 2
SERVER CONFIGURATION
On its own, Apache can serve HTML files over HTTP, and with additional modules can serve dynamic web pages using scripting languages such as PHP.
--> sudo apt-get install apache2 -y --> cd/var/www/In this directory, the default webpage is added which is designed using bootstrap with file name as index.It can be seen by the command
--> Sudo vim index.html Web camera configuration: -->sudo apt-get install motion -->sudo apt-get install libv4l-0 -->sudo apt-get install uvccapture -->cd /etc/default/motion and set "start_motion_daemon" to yes -->cd /etc/motion/motion.conf with the following settings
set "daemon on" set "pre_capture 2" set "post_capture 2" set "output_normal on" set "quality 100" set "ffmpeg_cap_new on" set "ffmpeg_timelapse 30" set "ffmpeg_variable_bitrate 2" set "get_dir /media/webcam/motion" set "webcam_port 8080" set "control_port 8081" set "webcam_localhost off" set "width 640" set "height 480" give /media dir access rights --> sudo chmod 777/mediaStart motor with
- sudo/etc/init.d/motion start
- if you want to stop motion: sudo/etc/init.d/motion stop
- check the browser if the picture is displayed: http://localhost:8081
Pi Camera configuration
Go to /usr/src/ and create a directory mjpeg-streamer there:
Steps:
--->cd/usr/src --->sudo mkdir mjpg-streamer --->sudo chown ‘whoami’:users mjpg-streamer --->cd mjpg-streamer --->git clone https://github.com/jacksonaliam/mjpg-streamer.git.
--->apt-get install libv4l-dev libjpeg8-dev imagemagick build-essential cmake subversion --->cd mjpg-streamer-esperimental --->Make
Now one should be set to start streaming the video. There are many options you can set. Here, we will do a simple example of streaming of 640×480 resolution video at 30 frames per second. If you lower the resolution, the latency will get smaller.
--->export LD_LIBRARY-PATH=. --->./mjpg_streamer-o “output_http.so - ./www” –I “input_raspicam.so –x 640 –y 480 –fps 20 –ex night”The export LD_LIBRARY_PATH variable sets the current directory as a path where programs should look for libraries. Our program uses output_http.so and input_raspicam.so libararies found in the current directory, which is why we added that directory to LD_LIBRARY_PATH.
3Step 3
USER END (CLIENT) WORKING
- Initially the user has to visit the website of the remote observatory system (as of now it cannot be accessed globally since we haven’t got patent.
- Once done, it will be hosted to access website and motor control can be done using port forward technique) designed using bootstrap, where it includes all kind of datum such as booking the slots, research on astronomy, astro-photography and so.
- From the booking session, user has to select the time slot and duration for the control of telescope. Once the user has selected the slot and made the payment had been done, user will receive the mail (using smtp) which has the time slot, user name, password created by the user during slot booking and the link of the control panel where all these functionalism are designed using php, CSS and HTML.
- User can login at the slot time with clearance of 2 minutes. Once the user has logged in, he can control the telescope.
HOST END (SERVER) WORKING
- The server used for this project is apache2, which runs on raspberrypi.
- Once the python program starts running in pi, it will create a connection with websocket through tornado port.
