The tiara is 3D printed (headband, crystals, and microcontroller case).
It's run by an ESP8266 breakout + LiPo battery.
You can type commands into Twitch such as `tiara on`, `tiara off`, `tiara red` or even hex colours like `tiara #00ff00`.
There is a short Youtube video here with an early code example (it's been DRY'd up since): https://www.youtube.com/watch?v=mxmfkz-kXX0 I wrote the code live on Twitch, and then my viewers tested it for me!
It connects to an MQTT broker and listens for incoming messages. I have set up a NodeJS app which listens to the Twitch chat channel, and reacts when there are tiara commands coming through from viewers. It will dispatch a message to the tiara via the MQTT broker to change the colour. The NodeJS app is hosted remotely in the cloud.
The code and 3D files are on Github here: https://gith
