"Don't rely on GOD, who knows if he's relying on you"
- Dashrat Manjhi (The Mountain Man)
Challange: CLIMATE CHANGE
- IMPACTS
Higher Temperatures
Changing Landscapes and Wildlife Habitat
Rising Seas
Increased Risk of Storms, Droughts, and Floods
Communities at Risk
Economic Impact
- The MAIN CAUSE: DEFORESTATION
Forests help protect the planet by absorbing massive amounts of carbon dioxide (CO2), the most abundant type of pollution that causes climate change. Unfortunately, forests are currently being destroyed or damaged at an alarming rate. Logging and clearing land for agriculture or livestock release huge amounts of carbon dioxide and other harmful greenhouse gases into the atmosphere. It also diminishes those regions’ ability to absorb carbon pollution.
13% Scientists estimate up to 13 percent of global carbon emissions come from deforestation – greater than emissions from every car, truck and plane on the planet combined.
- How does AutoWats HELP combat this CHALLANGE?
The only way we can overcome all this challenge is if each of us contribute towards this and the only way a common man can do this is by having a few plants at home. But it's not possible for everyone to manage and handle plants on a daily basis due to the busy schedule and lack of skills...but no more worries because AutoWats is here!
WHY AutoWats?
- 100% Automatic!
- Satisfies 3 Rs
- Cheap ($20- FULL SET)
- Won't break by slight SHOCKS.
1. 100% Automatic- You just need to do the 'SIMPLEST Setup' and that;'s it.
Later on, you'll just change the battries in Tapo yearly (IN THE FUTURE UPDATES I WILL MAKE THIS AUTOMATIC BY ADDING A ELECTRICITY GENERATOR IN THE SOLENOID VALVE OPENING WHICH WILL USE THE FORCE OF WATER TO GENERATE ELECTRICITY)
2. Satisfies 3 Rs-
Recycle- Both the parts are made of PP-
Polypropylene is a polymer plastic that is a member of the 'polyolefin' (polymers produced from alkenes) family. It is a highly versatile material that has many beneficial physical properties, and most importantly it is also recyclable.
Reuse- If you don't want to use them anymore(THIS WILL PROBABLY NEVER EVER HAPPEN BECAUSE ONCE YOU USE IT YOU WILL FALL IN LOVE AutoWats) you can just takeout the stuff inside the container and then use the cases as CONTAINERS after a wash.
Reduce- The size of AutoWats is the smallest compared to anyother plant watering system in the market and also, the low height and long HxB of Tapo makes it VERY STYABLE and the CONE SHAPE of Planti improves it's balance.
3. Cheap- If we actually add all the cost of the components used this project at BULK RAT then the cost I am getting is around 20 bucks (USD).
4. Balance- As mentioned above, Tapo is protected with a thick layer of protective plastic which makes shock proof and Planti balances soooooo well that it has NO HOPES OF FALLING making AutoWats(Tapo + Planti) SHOCKPROOF.
SIMPLEST Setup:
1. Just take Planti, turn the switch on & and insert it in your pot.
2. Turn on Tapo Connect Tapo to you tap and then attach the pipes on the other end of Tapo, and put them in your pots, garden and bushes.
Summary: AutoWats is a revolutionary plant watering system which is designed for the use of common people and is completely (100%) wireless.
Working: Planti receives the inputs from it's sensors, then sends it to Tapo using 433mhx rf transmitter module (wireless connectivity module...
Siddhant Choyal
GOAT INDUSTRIES
Pradeeplogu
Jan Godde
Wow, you have a very good project. I like it. And the main thing is that you are raising an important topical topic of globalwarming. Now more than ever new ideas in this direction are needed. After all, every year our influence on the planet is becoming more terrible. Here https://climatescienceamerica.org/free-essays/globalwarming.html is a detailed description of the state of the environment now. I think you can already start worrying. But looking at projects like yours, I believe that all is not lost and we can save the planet.
