Now it should be enough
A project log for YGREC-РЭС15-bis
YG's 16bits Relay Electric Computer, rebooted
yann-guidon-ygdesYann Guidon / YGDES 04/22/2017 at 09:031 Comment
That moment when you order 5 lots of 2K diodes, and you receive a pretty large reel of 10K diodes.
"normal" reel size for scale.
The DRAM should be covered now, and there is only 1 part and 3 soldering joints instead of 4 soldering joints and 2 parts.
I also received the KOA diodes in SSOP24. The 1100 pieces should be enough for about 730 instructions. Good thing I extended the PC to full 16-bits width :-)
[deleted]
