I found even faster transistors than the BFS480...
The BFP420 is 3x faster, at 25GHz gain-bandwidth product ! This means a gain of 25 at 1GHz, for example.
I received a few hundreds for tests. They are of course more expensive and are packaged alone in a small package (4 pins ??) so the density is lower but it could be helpful for the critical datapath, like the ALU.
I doubt I could measure the frequency of a ring oscillator made with it so I'll have to implement at least 9 stages ! :-P
One important limitation is the operating voltage : 4.5V so this limits the possible topologies.
OTOH it could also be used to build a very good picosecond pulse generator at low voltage :-P
Yann Guidon / YGDES
I also bought some of these and actually designed a PCB with an LNA, but never dared to test it. The application note is seriously scary (to me at least, maybe not to those well versed in HF black magic) - they use inductive emitter degeneration by some strategically placed vias. Also, the 4.5V limit is apparently quite strict and you can easily kill the device.
"For oscillators up to 10 GHz". Well, I guess building an oscillator is always easier than building an amplifier with devices like these.
"inductive emitter degeneration by some strategically placed vias."
wut
"the 4.5V limit is apparently quite strict and you can easily kill the device."
I suppose so...
"building an oscillator is always easier than building an amplifier with devices like these."
And not only those...
Would you share the appnote with us ?
Is this LNA a project on HaD as well ?
I think it was this appnote:
https://www.infineon.com/dgdl/Infineon-AN_1805_PL32_1806_113119_design%20guide%20for%20low%20noise%20transistors%20-AN-v01_00-EN.pdf?fileId=5546d46265f064ff016643d954321028
I notice now that it does not explicitly mention the BFP420, but it is generally about LNA design with SOT343 packages. I also got some BF776 in SOT343.
The LNA is not on HaD. I built up one version with BFU520W and got to about 350MHZ BW (and no oscillation or overshoot) at 19.4 dB gain. The design used shunt feedback. I would do it differently now.
look for the pink light at bends in the traces j/k
I don't get it...
cherenkov radiation? :)
muahahaha
the traces will leak photons pink in color from forcing the electrons around the corner
You mean "synchrotron effect" ? :-D
At 11 Eurocents each in 1K qty (Farnell) I wouldn't call them particularly expensive - just a little bit more than double the price of plain old BC547's.
BC547 can be sourced as low as .2 to .015€...
https://www.ebay.de/itm/1000-x-BC546B-Si-Transistor-NPN-65V-0-1A-0-5W-TO-92/312004936430 : 14€, or 20€ incl. shipping and taxes.
BFS480 has 2 transistors per package, which is pretty price-effective and dense on the board.
Well, you really can't compare prices on eBay with a proper supplier like Farnell. (Which had the prices I quoted). Oranges and apples you know ;-)
@matseng in fact... I can ;-) and dollars are dollars ;-)
I wonder what kinds of steps you need to take to discourage parasitic oscillations at some ridiculously high frequency with these things. How would you even know if it were oscillating at 10+ GHz?
to prevent resonance, you have to use the https://en.wikipedia.org/wiki/Barkhausen_stability_criterion : add phase or have gain <1 at the unwanted frequencies...
