18cm x 12cm veroboard
JPEG Image -
3.89 MB -
04/04/2017 at 10:22
Preview
Basic collection of the bits used. The SD card adapter was changed for a micro sd card adapter
JPEG Image -
3.45 MB -
04/04/2017 at 10:21
Preview
First hookup to the dehumidifer, testing the relay control action
JPEG Image -
3.24 MB -
04/04/2017 at 10:21
Preview
JPEG Image -
3.25 MB -
04/04/2017 at 10:21
Preview
Initially had an OLED display but decided to can it as it would be used infrequently
JPEG Image -
3.40 MB -
04/04/2017 at 10:21
Preview
Final layout of the module. I initially used a DHT11 sensor but subsequently switched to the DHT22 (more reliable)
JPEG Image -
3.14 MB -
04/04/2017 at 10:20
Preview
JPEG Image -
3.01 MB -
04/04/2017 at 10:20
Preview
The DNC65 control board. I attached to the anode side of the indicator leds to get the status of operation
JPEG Image -
3.64 MB -
04/04/2017 at 10:18
Preview
Initial testing of a ESP8266-01
JPEG Image -
3.40 MB -
04/04/2017 at 10:17
Preview
Initial testing using a Arduino Nano
JPEG Image -
3.25 MB -
04/04/2017 at 10:17
Preview
Testing the use of a ttl level shifter
JPEG Image -
3.24 MB -
04/04/2017 at 10:17
Preview
Bathroom scales connected to the HX711 load cell amplifier
JPEG Image -
3.20 MB -
04/04/2017 at 10:16
Preview
Before removing the original control board from the scales. I hooked up the load cells to a Sparkfun Load Cell Combinator board and then onto the HX711
JPEG Image -
2.52 MB -
04/04/2017 at 10:16
Preview
