In order to continue the development on my Linux machine, it was necessary to:
1) Install the Arduino IDE
Download and unpack the Arduino IDE 1.8.2
https://www.arduino.cc/en/Main/Software
Read the installation guide, but before proceed to the installation it might be necessary to edit the installation script.
https://www.arduino.cc/en/Guide/Linux
If you get errors during installation try this:
Edit the install.sh script and edit the following line:
RESOURCE_NAME=cc.arduino.arduinoideChange it to :
RESOURCE_NAME=arduino-arduinoide
then run the ./install script (note: without sudo!!)
2) Install the Digispark support add-on
https://digistump.com/wiki/digispark/tutorials/connecting
3) Create a udev rule to allow the micronucleus bootloader to work without being root.
https://github.com/micronucleus/micronucleus/wiki/Ubuntu-Linux
This file shall be created as a root. In Ubuntu:
sudo mousepad /etc/udev/rules.d/49-micronucleus.rules
mousepad is the name of the text editor. Can be either gedit, vi, emacs, etc...
