DIY_Polishing_Station_v1.0.ino
Arduino code
ino - 15.59 kB - 05/07/2023 at 17:14
Download
Optimal position of humidifier cover in relation to the polishing platform. This ensures that mist coming from humidifier will easily reach the platform. Also, being in the front (rather than the back) makes the mist more visible while polishing.
Portable Network Graphics (PNG) - 36.64 kB - 04/08/2017 at 18:58
Preview
Bulbasaur model printed using PolySmooth (Snow White) with 1.6mm wall thickness, polished for 35 mins. using 70% ethyl alcohol.
JPEG Image - 6.37 MB - 04/09/2017 at 07:15
Preview
Before and after polishing: Bulbasaur model printed using PolySmooth (Snow White) with 1.6mm wall thickness, polished for 45 mins. using 70% ethyl alcohol.
JPEG Image - 6.80 MB - 04/09/2017 at 08:03
Preview
platform.stl
Standard Tesselated Geometry - 648.62 kB - 04/06/2017 at 05:27
Download
controller front panel.stl
Standard Tesselated Geometry - 141.20 kB - 04/06/2017 at 05:27
Download
rotary encoder mount.stl
Standard Tesselated Geometry - 23.81 kB - 04/06/2017 at 05:27
Download
screw gasket.stl
Standard Tesselated Geometry - 20.30 kB - 04/06/2017 at 05:27
Download
pogo pin housing - lighting.stl
Standard Tesselated Geometry - 52.23 kB - 04/06/2017 at 05:27
Download
gasket with screw cover.stl
Standard Tesselated Geometry - 63.02 kB - 04/06/2017 at 05:27
Download
power panel.stl
Standard Tesselated Geometry - 89.73 kB - 04/06/2017 at 05:27
Download
pogo pin lighting connector.stl
Standard Tesselated Geometry - 15.90 kB - 04/06/2017 at 05:27
Download
platform attachment.stl
Standard Tesselated Geometry - 49.79 kB - 04/06/2017 at 05:27
Download
pogo pin housing - humidifier.stl
Standard Tesselated Geometry - 31.28 kB - 04/06/2017 at 05:27
Download
neopixel base.stl
Standard Tesselated Geometry - 32.55 kB - 04/06/2017 at 05:27
Download
neopixel diffuser.stl
Standard Tesselated Geometry - 61.70 kB - 04/06/2017 at 05:27
Download
encoder knob.stl
Standard Tesselated Geometry - 62.58 kB - 04/06/2017 at 05:27
Download
humidifier cover.stl
Standard Tesselated Geometry - 165.22 kB - 04/06/2017 at 05:27
Download
stepper mount - 28BYJ.stl
Standard Tesselated Geometry - 63.17 kB - 04/06/2017 at 05:26
Download
controller panel cover.stl
Standard Tesselated Geometry - 65.61 kB - 04/06/2017 at 05:26
Download
bracket (for snapware).stl
Standard Tesselated Geometry - 15.51 kB - 04/06/2017 at 05:26
Download
stepper mount - NEMA 14.stl
Standard Tesselated Geometry - 35.82 kB - 04/06/2017 at 05:26
Download
bottle top.stl
Standard Tesselated Geometry - 69.76 kB - 04/06/2017 at 05:26
Download
bottle body.stl
Standard Tesselated Geometry - 28.79 kB - 04/06/2017 at 05:26
Download
wick holder.stl
Standard Tesselated Geometry - 49.59 kB - 04/06/2017 at 05:26
Download
stepper nut.stl
Standard Tesselated Geometry - 59.85 kB - 04/06/2017 at 05:26
Download
stand offs.stl
Standard Tesselated Geometry - 6.14 kB - 04/06/2017 at 05:26
Download
stand off for humidifier PCB.stl
Download
