1Step 1
Choose a car, preferably without power steering. Remove all ICE components.
2Step 2
Purchase a high power electric motor, a speed controller, batteries, heavy duty wire, battery chargers, a DC vacuum pump, a DC-DC converter, and main power relays.
3Step 3
Custom machine a coupling adapter for the motor to the preexisting transmission, weld support brackets. Install motor.
4Step 4
Create mounting brackets for all other components. Install batteries, wire speed controller and motor.
5Step 5
Install DC-DC converter, vacuum pump, heating coil and accelerator pedal.
6Step 6
Test drive.
James Hobson
