1Step 1
Wait a bit longer for the revised files and parts.
2Step 2
If that fails, print the parts and insert the captive nuts.
3Step 3
Populate and solder the PCBs.
4Step 4
Assemble the LED sub group with the battery holder.
5Step 5
Connect the LED, battery and NTC wires.
6Step 6
Flash the firmware.
7Step 7
Install the switch mechanism.
8Step 8
Slide the driver PCB and battery holder into the main body and screw everything together.
Peter Fröhlich
