The process of designing v4.0 of the board has begun. We have chosen to modify the design slightly with this update. This update will also bring the battery management circuit onto the board, a power switch, and buttons that are better suited for manufacturing. This version will also add test points and holes for mounting the device in a case. Here is quick look at the proposed board redesign:
awesome! I really hope it works out for you, looks like a really awesome design
this is awesome. I hope I could one day get the pcb and parts list from you. As far as I can see there is very little parts. Looks like my dream of a good pi hand held might come true
Thanks! Glad you like it. We are still thinking we might be able to manufacture and sell the device. If that dream doesn't come true, we will absolutely open source the design files.
