Configuring Includes in VSCode
In VSCode you'll see the "mbed.h" underlined in green as not found
- press "ctrl+shit+p" and click on "Edit Configurations"
- Under the includePath of your matching operating system, add the include
"name": "Win32",
"includePath": [
"C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include/*",
"C:/Users/User/.platformio/packages/framework-mbed"
"browse": {
"limitSymbolsToIncludedHeaders": true,
"databaseFilename": ""
You should now be able to navigate, such as right click and the "Go to Definition" would open the file for you in VSCodeBefore debugging
- You might want to finish compiling and flashing first
Debugging with VSCode (Start is right then got stuck)
well, haven't we seen this tool somewhere already ? Going back to the ".platformio\packages\tool-stlink" we find all of
st-flash | the flash utility used with the command line above |
st-info | retrives information (flash, srma,... see help) |
st-util | this is the magic utility that changes your ST-Link HW+SW into a gdb server |
- run "st-util" from the command window (outside VSCode)
- From VSCode, click on "Debug" icon or menu, then click on config
I'm using this configuration
"version": "0.2.0",
"configurations": [
"type": "gdb",
"request": "launch",
"name": "Debug Microcontroller",
"target": "extended-remote /dev/cu.usbmodem00000000",
"executable": ".pioenvs/bluepill_f103c8/firmware.elf",
"cwd": "${workspaceRoot}",
"autorun": [
"monitor tpwr enable",
"monitor swdp_scan",
"attach 1",
"load .pioenvs/bluepill_f103c8/firmware.elf"
"type": "gdb",
"request": "attach",
"name": "Attach to gdbserver",
"target": ":4242",
"remote": true,
With this, you can connect to the gdb server, load the program, but then I failed to step, I got an error, so here's where any help would be appreciated. I think the platformIO are working on an IDE with an integrated debug, well I bet it is the continuation of this process. But with the useful correct configuration that I'm probably missing.
im doing exact the same thing. my st-util is listening on port 4242 but i get this error in vs code :(
""Debug adapter process has terminated unexpectedly (exit code: null)""
Try to use the following configuration (VSCode):
"version": "0.2.0",
"configurations": [
"type": "gdb",
"executable": "${workspaceRoot}/build/firmware.elf",
"target": ":3333",
"remote": true,
"gdbpath": "path to arm-none-eabi-gdb.exe",
"autorun": [
"monitor reset halt",
"load path to firmware.elf"
"compounds": []
"target": ":3333" - 3333 is the port which opens gdbserver (openocd).
"load path to firmware.elf" - load is the command gdb.
