- >pio init --board bluepill_f103c8 --project-option="framework=arduino"
- then update content of platformio.ini
Content of the platformio.ini
[env:bluepill_f103c8]
platform = ststm32
board = bluepill_f103c8
framework = arduino
The main.cpp#include <Arduino.h>
void setup()
pinMode(PC13, OUTPUT);
void loop()
digitalWrite(PC13, HIGH);
delay(200);
digitalWrite(PC13, LOW);
delay(1000);
The compiler is the same "arm-none-eabi-g++" and the result isarm-none-eabi-size -B -d .pioenvs\bluepill_f103c8\firmware.elf
text data bss dec hex filename
6284 1920 312 8516 2144 .pioenvs\bluepill_f103c8\firmware.elf
So the Flashed code size is : 8 KB
