Recently I was able to create a PCB with this printer.
Here are the details: http://sedgwick3d.com/t/PrintPCB
A project log for Sedgwickâ„¢ the 3D DLP Resin Printer
Sedgwick the open source, easy to assemble, easy to use and economical 3D DLP Printer.
How well does the resin stick to the Copper/Laminate? Could you use the same technique to do a soldermask?
