This dome holder is something I've wanted to build for a few months. I finally got around to picking up all the elbow joints. It was designed by someone on the Astromech.net forums and works beautifully to make the inner dome accessible without scratching or damaging the outside.
Now that I can properly access the inside of the dome I can work on all the electronics I want to add starting with a proper lighting set up for that eye.
