I finally committed to bonding the inner layer of skins to the frame but first I wanted to paint the frame black in case any part was visible.
![](https://cdn.hackaday.io/images/1553681509897242801.jpg)
Then the process of bonding the skins started. First the inner layer was bonded to the frame. The outer layer was glued to the inner layer with Weldon.
![](https://cdn.hackaday.io/images/2942311509897318844.jpg)
I filled in some minor imperfections before priming the body. There are still some spots to be fixed before more priming and the base coat are applied. I also need to figure out the doors.
![](https://cdn.hackaday.io/images/7785471509897346760.jpg)
I originally only wanted the two long doors but during the process of attaching the skins I decided to add two more opening doors.
![](https://cdn.hackaday.io/images/8788131509897499034.jpg)
I'm not sure what I am going to put behind the doors yet but it will be something fun. Maybe more weapons. BT could always use more weapons. Speaking of weapons...
![](https://cdn.hackaday.io/images/8950841509897584462.jpg)
I finished the primary painting of the chaingun. I will paint the belt later. I want to try for a brass look.
