Two videos showing the different functions of the watch:
There are kits for sale or also complete PCBs with all the parts soldered:
https://www.du-kannst-mitspielen.com/p/bausatz-wortarmbanduhr-kit-for-word-wristwatch
The side is in German, but I'll answer in English, if you send me a mail. Cases are availible in anodized aluminium or wood (walnut and beech). The battery lasts more than two years now. There are different languages implemented (German, English, Dutch and others). You can show the time, date (as big number or running text), battery power, seconds. There is a manual time correction implemented, 4 different brigthness modes and even a night mode, where you can reduce the brightness. So everybody who is interested, let's get in touch!
bobricius
Bertrand Lemasle
nolandoktor
Hello @CF , it seems that some of the front planes are laser cut with the letters. Correct? If so, then isn't it a problem that somethin can attach to the letters and bend them over? Let's say you put on a t-shirt with the watch on and then the steel cover scratches slightly the t-shirt and can get bend?
