High side switch + AMA
A project log for PiDSP
Perfect DSP for your loudspeaker project. Add Raspberry Pi for playback capabilities
jan-petrikJan Petrik • 06/12/2017 at 20:37•0 Comments
Hi,
With B2 revision, there is no provision for powering down expansion board s(ADC/DAC etc.), which is pity. For B3 revision I've designed simple high side switch. Before I close the pcb design, I just wanted to test the switch, so I lets have some test-boards:
Second board is new and better power sequencing - resetting diodes and some minor tweaks.
Also we will have a AMA on 13.06. So if you feel like, please stop by!
