This is the latest version that uses the #Cardware method of enclosing the instruction card. I also have found some ceramic magnets that have greater holding pressure and this results in a solid contact.
This card is wired for code 5 - Move pointer right one position
Could you reduce the number of magnets ? I would have a strong one on the base and just metallic junk in the instruction cards...
Sure could and not a bad idea as there will be many cards :-) Thanks Yann :-)
