Captains Log #9 :R.I.P Chip Pro
06/07/2017 at 15:56 • 1 commentOutstanding service for 4 months. Ill get another chip pro, I will have to make a redesign since the lower pins barley lasts a re-solder
Captains Log #8
04/30/2017 at 06:15 • 0 commentsOrdered the PCB via OSH park :), now we wait.
Captains Log #6
04/29/2017 at 20:49 • 0 commentsIn this revision I removed the LED for an MAX9803 2 channel amplifier.Added 2x trimmer for gain control.
Captains Log #5
04/28/2017 at 23:08 • 0 commentsA quick redesign will be added to add a 2 channel ampilier
Captains Log #4
04/26/2017 at 04:59 • 0 commentsJust designed aand 3D printed a little Bumper case for the Prototype Boom box, It is also included in the mini BoomBox DIY Kit.
Captains Log #3
04/25/2017 at 17:02 • 2 comments -
Captains Log #2
04/23/2017 at 00:34 • 2 commentsSo far I made some changes on the PCB board.
- Tapered soft corner edges
- Added more Speaker Holes
- Swapped the upper gpio through holes with silent SMD tactile buttons (they are comfortable to press)
- Grounded the top layer so the art design solder mask shows copper instead of the bare pcb layer.
- Added a power on/off button smd button connection.
Captains Log #1
04/21/2017 at 22:10 • 0 commentsI tested the speakers I ordered and they worked great on the L and R channels, they were soft sounding speakers so I will replace it, with louder speakers, and also update the PCB silkscreen design.
