Problem with output logic levels
A project log for Simple counter/clock
4-bit counter hooked up to 7-segment display showing succession of hexadecimal digits
pavelPavel • 04/14/2017 at 04:51•0 Comments
For decoder I used simplest diode 4AND logic gates (image), assuming they would work properly, and give +Vcc for high and 0.6V for low.
Unfortunately, output for HIGH is measly 1.6-1.7V and it is too low for driving display unit.
I am still cannot understand, why is it so.
