PCBs are shipping from EasyEDA and will arrive probably Monday. I have also received all components. I have also updated my FPGA design to match the PCB, so I should be able to run the same software on both platforms. This will hopefully help me to debug any issues with the PCB. I have my assembly procedure listed on the project details page, and I plan to test as I go to make sure each part works as expected before I build the next part.
I also have my EEPROM programmer code all working. So I can generate an Intel HEX file to download to the EEPROMs for each of my three EEPROMs in the design. ALL SET TO BUILD!
