First Batch: Assembled Modules
A project log for [ModAir] Monochrome LCD Modules
A LCD graphic / character display module for the ModAir project
reneRene 04/20/2017 at 13:260 Comments
The idea with the controller and LCD sandwiches is to mount them directly behind a front panel. I had a front panel cut from 0.9 mm brushed stainless steel (about $10 from a local metal manufacturing company), but unfortunately I only discovered the scratches underneath the protective plastic when I got back home.
The 3D printed brackets worked perfectly, and aligns nicely with the PCBs on both sides. In the design files I added 0.2 mm on all sides.
For the 1602 LCD, the PCB is cut smaller with a hacksaw. For this module, the rotary encoder is mounted on the base PCB (rather than being attached with a ribbon cable).
Rich text editor
