Hello,
After assembly and testing I found the forgotten resistor at the reed relay. Pin arduina remained undefined. Fortunately, the relay was connected to Pin 2 which is just next to the ground. Using the 10K SMD resistor 10K size 0402, I fixed it on my finished boards. I also made it into a schematic drawing and board design so I uploaded a new version.
